This pertains to processing vinyl LP's & 45's.
Some time ago, on one of the earler versions of DC Art, it seems that I read that we should eliminate the larger Scratch & Crackle noises first; then, progress to eliminate the smaller Scratch, Crackle, Narrow Crackle, then Continuous noise, then perhaps 60 Cycle Hum and Hiss, then Manual Declicking when necessary. Otherwise processing from the highest to the lowest order of filtering.
I have pretty much started filtering from the lowest noise levels and progressing to filter through to the higher noise levels.
Is there a preference as to the order of processing the various filters?
