If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
DCart10.7 is now Introduced; Check out its large feature set and new very low price
DCart10.7 will not install over 10.6. Popup says I already have a newer version.
About in my DCart definitely says I currently have 10.6. I have tried at least 3 different times
with same result.
Forgot to mention I am on current version of windows 10.
Don't think I got a response on my problem above. Why does DCart 10.7 think 10.6 is a newer version
and won't install?
Is it 10.06 or 10.6 as the previous version. I am aware of a bug in 10.06 which reports the previous version incorrectly. Print the help/about dcart screen for insurance. Here is what I suggest if you do if have version 10.6. Uninstall it. Then download the demo version of 10.7 and install it. Your serial and registration should be maintained (in the computer registry).
About window said 10.6 but I did what you suggested and 10.7 installed with no hitch. Thanks
Just re-installed 10.7 on new computer. Only issue seems to be Playback, which stops after ~ 4.7 seconds. Did I screw something up on playback settings?
Not sure, but that symptom is often reflective of the drivers being set incorrectly. Goto Edit/Preferences/Soundcard and make sure that WDM drivers are checked, especially on Win10 operating systems. MME drivers do not seem to get along with Win10.
