DCArt11 operating on LINux via WINE
  • DCArt11 operating on LINux via WINE
    "I use DCart11 via WINE on my Linux System, and it works..."
    Kind Regards
    Franz​ Westpointner
    WINE is effectively a Windows Emulator which permits Windows software to run on LINUX. It can be found here:
    https://www.winehq.org/
    "Windows applications on several POSIX-compliant operating systems, such as Linux, macOS, & BSD. Instead of simulating internal Windows logic like a virtual machine or emulator, Wine translates Windows API calls into POSIX calls on-the-fly, eliminating the performance and memory penalties of other methods and allowing you to cleanly integrate Windows applications into your desktop."
