It is good practice to back up your Diamond Cut Productions.msi installer software after you have installed the program on your machine(s). That way, it will be available should you encounter a hard drive crash or other computer malfunction. Put it on an external USB hard drive or equivalent. If you ever have to restore the program, you will have to move it from the external hard drive to a directory on your C drive and then re-install the software from there. It will not install directly from the external USB drive.
The size of the backup depends on the program. For example, DCForensics10.52 occupies roughly 60 MBytes. DCArt10.51 occupies roughly36 MBytes.
