There is a demo wavefile called "Dyna Bass Demo" found under the file/demo wavefiles menu which is a lateral cut mono transferred 78. It is useful for two circumstances. One is to practice using the EZ Impulse Filter in a selective manner. That file has impulse noise bursts near it's end (from 02:34 to 03:04). Simply highlight the noise bursts and run the EZ impulse filter on those and an excellent result will ensue. Adjust the Crackle slider fairly aggressively and the other two sliders at the top of their green zones. The other application for this demo file is the use of the Dyna Bass effect which you can experiment with. We recommend starting with the Dyna Bass presets to find a good starting point and then take it from there with fine tuning of the Dyna Bass controls.
ps - The Song is "True Blue Lou" by Annette Hanshaw
