Yout Tube excitement filter
  • Yout Tube excitement filter
    As stated - run over film clips from You tube. This filter attached will be found under the multifilter presets menu, and is titled "You Tube Filter" and will probably appear almost last on your list. Make sure The fat bass VVA does not overload on some materials by reducing the "Drive" value. I have already dropped it to about 70 units.
    Same for the harmonic sweet spot, sometimes more drive sounds better, in this case I have dropped the mix value since I am following it with the expander.
    Regarding the expander, you can also increase the expansion in the punch and crunch on some materials to brighten the sound more. At the moment, I have the ratio of expansion at 1.3, but sometimes upto 1.5 will sound best. Also try playing around with Low-Mids expansion on some material for a better sound.
