I just received Jeff at Tracer's newletter and he mentioned that there are a couple of new features in ver. 1.4. What are they?
Also, since I am a "newbie" when it comes to Mentor, I still trying to figure out all of it's capabilities, to determine when and if I need to shell out to DC6 for a particular task.
Most of my restoration work is with albums. Sometimes I need to trim the silence between individual tracks because of excessive silence. I just noticed something yesterday while working on a restoration and I don't know if it normal of the program or not. I was trying to 'trim' an excessive amount of silence between track2 and track3 on an album side. It was a single file that had been "marked" by Mentor to show where the tracks would be divided later. I began by selecting 'trim start', as it would be the start of track3. I highlighted track3 and made a rough highlight of the area I wanted to trim. It was actually a little bit longer than I wanted to trim, so I hit 'trim less' and the highlight moved to the beginning of the file. I found out that Mentor does allow for 'trims' within the file, because I successfully did that, but the 'trim start' and 'trim end' always refer to the beginning and end of the entire file.
Since Mentor treats even multiple tracks as one until the burn phase, I was wondering if this is normal? If it is, that is perfectly OK as I could shell out to DC6 and perform a chop function and finish within Mentor.
For those of you that are professional Mentor users out there this may seem like a dumb question, but at this point I am just trying to figure out what Mentor is capable of doing, so I know when to go to DC6 or when to stay within Mentor.
Any input would be appreciated..
GB
GB
Mentor was never designed with the intention of supporting multiple CD drives. After all, you only need one drive to make your CD, so we still do not comprehend the need for this feature anyway. And, the product was never advertised to support multiple drives. That was not one of its advertised features.
