Waveform Statistics Resolution ?
  • Waveform Statistics Resolution ?
    Group,
    The units for the Forensics Waveform Statistics reflect the units for the waveform display (counts, dB, etc.). When the counts are used, the calculations round off the displayed values quite a bit; i.e. for 24 bits sampling the value shown is 8M for max value. However, when the value is low; i.e. below 1000 then the display shows exact number of counts.
    I am looking for more resolution in the statistics. Currently I use the dB value as I have one decimal place shown.
    Is there a way to increase the resolution to the displayed numbers for counts and dB? Say for counts show the actual digital value and not a rounded value.
    Not that I am aware of, especially since 24 bit audio is actually not achievable in the real world. (It falls into the category of psycho-acoustics).
      24 Bits was used as an example. Other bit depths have a similar scaling and could use more resolution.
        In 30 years in the market, we have never encountered such a request before. So, what the software has seem to be sufficient.
          O.K. Then. I will avoid asking for info\changes to your product.
            Yeah; try another software which may be more appropriate for your needs.
