Greetings all,
This is my first post, although I have been reading the entries of others for quite some time, and have made personal contact with a few members here and there. At this point I must congratulate Craig and Rick for such a wonderful support network for DC users. A fantastic resource - very much appreciated.
At last I've mustered the courage to go public with a couple of questions and would be grateful for any perspectives / experiences.
For both vinyl and shellac transfer I have noticed that when establishing a multifilter chain that the paragraphic EQ needs to be at the front end of the chain, otherwise a bubbly distortion can manefest, and I have less scope with the INF filter thresholds. Is this for any particular reason? As I use a flat preamp, my intuition suggests that I would be better filtering first and finally applying RIAA. I do everthing at 96/24 and dither down for the CD prep. I find that there is considerable more flexibility at the higher sampling rate.
I also wonder about using the CNF after the Paragraphic (RIAA) in the chain, as I believe that when sampling noise, it does so independently from oher filters in the chain (samples the raw 'flat' signal), but when engaged, it is effectively 'downstream' from RIAA. Wouldnt the noise characteristics therefore be different in application compared to the sample fingerprint? This may be a naive question...?
Finally, I have noticed that sometimes when I go to downsample and normalise etc, the system defaults to the non-filtered raw file rather than the one I have just filtered / editted. I must be doing something incorrect here (I get about it by saving the filtered file under another name, closing everything and beginning again from here)
Oh yes...I am hoping to put together a couple of portable turntables for remote use and I wonder if the flat pramps (CTP1000) are available as a prebuilt circuit board only, as I hope to mount them at the base of the tonearm? My current flat pres are from a homemade kit, but I thought it may be interesting to explore other options also.
Many thanks for your indulgence.
Stephen
Stephen
