Batch processor W/ Speed change
  • Batch processor W/ Speed change
    Is there any way to turn off the warning that pops up when you do a speed change inside the bach processor? (It says someting about changeing the length of the wav file)
    The reason I ask is I am doing a job for a guy and I recorded 10 LP's front and back at 45rpm. I planned on using the speed change to change them back to 33.3rpm. While the batch allowed me to set up the batch, I got the warning about file size change for all 20 files. This warning defeated the reason for running a batch file.
    This one sounds like a bug to me. I will put it on the DC6 bug list.
      Please keep me informed.
        I think that if you a) select a different directory for the speed change action or b) tell it to close the files it doesn't give you that warning, but I'm not certain of that. Seems like I figured a way around that before.
