buzz problem
  • buzz problem
    I have a piece of music that has a buzz in the audio spectrum. It was recorded in the mid to late 60's by an amateur and transfered to vinyl by a company in Chicago named Delta. It is a custom album by an A Cappella choir that was sold for fund raising purposes.
    Is it possible to send in a snippet of the buzz to see what it is frequency wise?
    I have tried the CNF but it seriously effects the actual music I am trying to restore. Any help would be appreciated.
    Thanks
    Hi Rick,
    Sure - - - send me a 10 second snippet of the material and I will report back what I learn about it. Send it to:
    dctools@aol.com
      I worked with that file and was able to reduce the buzz with the Harmonic Reject Filter using the following settings:
      Freq: 60 Hz
      Attenuation: 80
      Maximum Harmonic: 100
      Odds Only
      Let us know if you think that helps.
        Thanks Craig, I will give it a try in the morning. I am working graveyard at work till the end of the year.
          I gave this fix a try and it worked like a champ. Thank you
