Attempts to Run DC7 on Win 2000
  • Attempts to Run DC7 on Win 2000
    Konstantin from our German distributor has attempted to run DC7 on Win 2000. Here are some comments that he sent to Rick and I pertaining to his attempts. Here they are for any who may be interested:
    Since I tested the below on my own systems only so far, I went a bit
    further and used a "naked" Windows 2000 SP4 system and tried to see if I
    could verify my observations specified below.
    I found out that apart from the "mfc80.dll" there are more DLLs
    missing before DC7 would really start on a Windows 2000 system. I
    went through all DC7 startup messages one by one and finally came
    up with this list:
    mfc80.dll
    msvcr80.dll
    msvcp80.dll
    wmvcore.dll
    wmasf.dll
    wmidx.dll
    drmclien.dll
    msdmo.dll
    Does this list look familiar? I can imagine that all these dll
    files will be installed in the "systems32" folder when DC7 is
    installed. Is this correct? Looking into the DLL file properties it
    seems like the first three are related to Visual Studio 2005, the
    next three are related to Windows Media Services and probably part
    of a newer Windows Media Player than the version which normally
    came with Windows 2000, the seventh DLL is DRM and the last one
    DirectShow and both possibly also belong to a later version of
    Media Player.
    Then I copied all these files into the DC7 directory and it will
    start and come up with the registration dialogs.
    I was even able to start DC7 right from a CD which I burned.
    Best regards,
    Konstantin
    We do not support DC7 or Live / Forensics v. 7 for Win 2000, but for those that may be interested in experimentation on those systems, maybe Konstantins observations will be useful.
    keywords: DC7 on Windows 2000, DC7 on Win 2000, DC7 running on 2000, DC7 running on Windows 2000,
    it should be noted that it is not possible to run the DC7 installer on Windows 2000. It is necessary to copy an already installed DC7 (the DC7 folder) from a Windows XP or Windows Vista system and copy it manually to a Windows 2000 system.
    It should also be noted that the CD burner in DC7 will NOT work under Windows 2000. DC7 will immediately shut down when you click on the CD burner icon. But apart from that function all other functions (filters, effects, etc.) seem to work fine.
    Konstantin
      Hi Konstantin,
      Thanks - - - those are important clarifications for the folks who may be attempting to do this.
