de-essing tips
  • de-essing tips
    I am just an audiophile, no formal training or pro experience as a technician. As I archive my CD collection to .wav I am using DC7 to try and clean up some problem cuts, but I have not had any success de-essing using DC7.
    I have tried all the deessing related presets with no significant improvement.
    Using a spectral analyzer, I have found the problem frequencies to be between about 6K and 10K.
    Can anyone advise things to try beyond the presets?
    Thanks!
    Ken
    What ratio setting are you using and what attack and release times? Those play into the performance of the de-esser.
    Alternatively - - -
    You might want to try using the Punch and Crunch in compression mode with only the third band being active. Set the crossover frequency between the surrounding bands at 6 KHz and 10 KHz and then adjust the threshold value accordingly until the desired de-essing is achieved. Note - - - use a high compression ratio.
      Hi Craig,
      I did experiment with changing the attack and release times throughout their complete range. I could obtain some de-essing, but only when the settings were so extreme as to cause unacceptable distortion in other frequencies.
      I will try the punch and crunch and let you know the results.
      Thanks!
      Ken
        Just Curious
        Ken,
        Did you mean LP instead of CD? If so and you're having sibilance problems with almost all or at least a great deal of your LPs, you may want to make some setup changes to your turntable/cart.
          It just occurred to me to say the following about de-essing. If you have a very high noise floor on your file, the de-esser will not work. High frequency noise (or hiss) must first be reduced to reasonable levels else the de-esser will interpret the hiss as a "good" signal and not attenuate it.
