Missing Speed Entry
  • Missing Speed Entry
    Group,
    The "speed change" option in the effects menu disappeared from my DC7 software. I still have the ICON in the toolbar and it still works.
    I was using the batch process to change the speed of some Diamond Discs from 78-80. After the batch process finished, the speed change in the effects pull down menu seemed to disappear.
    I tried a re-start of DC7 and the menu option is still missing....
    Help!
    Regards,
    What!!!!
    Am I seeing things ? After some time using filter's, etc.....the change speed item in the drop down effects menu came back!
    Been drinking coffee today only...really.
    If I see a pattern, I'll let you know.
    Regards,
      Answer Found
      Group,
      O.K. If you do not have a file opened, then the change speed option does not show up on the effects drop down menu. When a file is opened, then the change speed option is shown in the drop down effects menu.
      If that's the way that the code was written, then that's O.K., but I would suggest a note in the help menu to that effect.
      Regards,
        h Marc -
        I think there are several filters/effects that aren't there unless you have a file open. It throws me every now and then also, but it makes sense.
        Click on the edit menu and you'll see a lot of stuff missing when no file is opened.
          Dan,
          I can understand the missing effects in that in order to DO Something you need "something"......
          I would suggest a general note in the help menu about the "missing" effects coming to life with a file could help.
          Regards,
            I added that to the DC8 and the Live/Forensics v.8 helpfile under the Edit menu description.
              It works the opposite sometimes too. If there is no file opened the Record function is available via the drop-down. However, if a file is opened, this option is not present in the drop-down, even though it's still available in the toolbar.
