I have an old, very hissy, multi-generation tape. I have another performance by this group on a different night, with some of the same songs, but in very clean condition.
I tried the spectral difference filter on it using the clean copy as the source, and it really makes a huge difference in the hissy tape - the instruments are much clearer, and overall the sound is very good, except the tape hiss increased dramatically. I read in the manual that you should do all the restoration work before applying the spectral difference filter, and I do that, but still get a very hissy result.
Is there any particular de-hissing that might work better in this situation? There's very little high frequency sound (music) on the tape I'm restoring above 5kHz , but the clean copy goes up to about 16khz, so it's really emphasizing the high end. I am having trouble cleaning up the hiss without also losing the signal.
Now that I phrased it that way, I guess that's really not any different from any other time we do hiss reduction - but the difference is the amplification afterwards.
Would it make sense to run the CNF before the spectral filter and run it again after to try to clean it up?
