LP Cleanup/Restoration - Order of operations
  • LP Cleanup/Restoration - Order of operations
    Hi All,
    Does the following seem correct/what you do?
    To clean up an LP
    First - run big click filter
    Second - set up multifilter and run a scratch/crackle filter (EZ noise removal or manual settings) set to remove light scratch (5-10 times in succession so that the scratches are progressively removed.
    THird - run a Continuous Noise Filter.
    Finally, manually interpolate the remaining glitches.
    Does this sound right?
    Cheers (and thanks in advance for feedback you may give,)
    eddie
    Hi eddie -
    I think the manual actually has the steps listed. Yours sounds like it will work fine, but you may want to check the manual. The main consideration is to de-click before any noise reduction.
      I have changed my clean-up somewhat.
      I used to do the manual fix at the end of the clean-up...but I found that the continuous noise filter seemed to "smear" the clicks somewhat and make them hard to find/fix.
      Currently, I manually de-click after I use the EZFilter and before anything else. In that way, the clicks and pops are easy to see and fix.
        Yes, that's exactly right, Marc. Best to de-click before the cnf. CNF should always be the last thing you do, I believe. I should have mentioned that earlier.
          Hi Folks,
          Yes - - - CNF (Continuous Noise Filtering) should always be performed after the Impulse Noise Filtering process is completed (EZ Impulse, Expert Impulse, Manual Interpolation {I-key or O-key}). That is the way that the system was designed to perform optimally.
          keywords: Filter Order, Impulse Filter Order, CNF Filter Order, Restoration Filter Order, Restoration Filters Order, Continuous Filter Order, INF Order, De-Clicking Filter Order, Filter Sequence, CNF Sequence, INF Sequence
            Thanks All.
            Much appreciated.
            eddie
            Originally posted by Craig Maier View Post
            Hi Folks,
              I generally start by de-clicking using the impulse noise filter (although 5-10 times seems a little like overkill to me), and then with the ease of scanning through the wave form like no other application does (thanks Craig and Rick!), I manually get rid of anything it missed (generally using the "I" command to interpolate), then run the CNF, and then run the EZ-Enhancer with the Audiophile preset slightly modified (which I love, to put a little extra high-end and punch back in the music).
              I have restored some albums for some friends of mine and they swear that I must have purchased the CD instead.
              John
                Quoting John:
                "I have restored some albums for some friends of mine and they swear that I must have purchased the CD instead."
                That is quite an endorsement by your friends of the quality of work that you do!
