Free Update to DC8.15 Released
  • Free Update to DC8.15 Released
    Hi Folks,
    We have just finished up a bug-fix release and made it available to all DC8 owners. You can download it from our website and your user name, serial number and registration code will persist. Download the Demo version here and it will be a licensed version for those who own the previous DC8x versions.
    http://www.diamondcut.com/store/inde...roducts_id=31l
    This update provides the following:
    Changes since DC8.13
    1) Fixed bug with resample function saving 8 bit files as 16 bits
    2) Fixed feature to save temp files in same directory as audio files. It was not able to be turned off.
    3) Added the ability to normalize left channel or Rigth Channel only. This appeard to work before but really did not. It would alays use the overall peak value regardless of channel.
    4) Fixed Track Spin control on the MP3 encoder dialog
    5) Fixed Spectrum analyzer when switching between files of different sample rates
    6) Fixed bug in batch editor when creating VBR mp3 files. It now uses the default settings from the preferences dialogs
    7) Fixed bug using spectral interpolate function. Some times it could crash on complex music
    8) Fixed Big Click filter bypass function
    9) Fixed bug opening an MP3 or other non-wave file from the command line
    10) Fixed bug in the click filters on mono files using solo mode. The bug would cause bad replacements in the audio
    Thanks, Craig - I'll download and install when I get home from work today.
    John
      Is this update for the forensics version also?
        No, this particular update applies to DC8 only. An update to the Forensics Version will appear in the near future.
          OK - thanks Craig
            I had DC8.13 installed and it could open the DC Tunes Libary. Downloaded and ran DC8Setup814.msi without uninstalling DC8.13 first. Setup ran to completion and DC8.15 opened. DC8.15 did not remember the location of my DC Tunes Library, so I changed the appropriate preference. I then clicked on the DC Tunes Library icon on the DC8.15 toolbar. The DC Tunes Library window started to open, but then 8.15 crashed with the following exception:
            The event log reports:
            Log Name: Application
            Source: Application Error
            Date: 6/4/2013 2:16:52 PM
            Event ID: 1000
            Task Category: (100)
            Level: Error
            Keywords: Classic
            User: N/A
            Computer: CAK2
            Description:
            Faulting application name: DC8.exe, version: 8.1.5.0, time stamp: 0x516d6a67
            Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b8f
            Exception code: 0xc015000f
            Fault offset: 0x00084621
            Faulting process id: 0x87e0
            Faulting application start time: 0x01ce6168cf51a5b8
            Faulting application path: C:\Program Files (x86)\Diamond Cut Productions\DC8.1\DC8.exe
            Faulting module path: C:\Windows\SysWOW64\ntdll.dll
            Report Id: 133252f2-cd5c-11e2-bf5f-001d092acafe
            Event Xml:
            <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
            <System>
            <Provider Name="Application Error" />
            <EventID Qualifiers="0">1000</EventID>
            <Level>2</Level>
            <Task>100</Task>
            <Keywords>0x80000000000000</Keywords>
            <TimeCreated SystemTime="2013-06-04T21:16:52.000000000Z" />
            <EventRecordID>40936</EventRecordID>
            <Channel>Application</Channel>
            <Computer>CAK2</Computer>
            <Security />
            </System>
            <EventData>
            <Data>DC8.exe</Data>
            <Data>8.1.5.0</Data>
            <Data>516d6a67</Data>
            <Data>ntdll.dll</Data>
            <Data>6.1.7601.17725</Data>
            <Data>4ec49b8f</Data>
            <Data>c015000f</Data>
            <Data>00084621</Data>
            <Data>87e0</Data>
            <Data>01ce6168cf51a5b8</Data>
            <Data>C:\Program Files (x86)\Diamond Cut Productions\DC8.1\DC8.exe</Data>
            <Data>C:\Windows\SysWOW64\ntdll.dll</Data>
            <Data>133252f2-cd5c-11e2-bf5f-001d092acafe</Data>
            </EventData>
            </Event>
            My PC is running Windows 7 SP1 Ultimate x64
            Any suggestions? I really like using the DC8 playlists.
              I am not sure why that happened. We did not see that during testing. However, you can re-create the DCTune Database by doing the following:
              Got to the C drive and search for the following two file folders:
              DcTuneDb
              and
              DcTuneDb.bak
              Delte both of them.
              Then, open the DCTunes and re-build the database.
                Thank you very much for trying to help me.
                I deleted the DC Tunes Library and move all of my playlists to a sub-directory.
                When I opened the DC Tunes Library, I got the same exception:
                Date: 6/5/2013 9:23:54 PM
                Event ID: 1000
                Level: Error
                Keywords: Classic
                User: N/A
                Computer: CAK2
                Description:
                Faulting process id: 0x179cc
                Faulting application start time: 0x01ce626d9be3948b
                Report Id: e5a81069-ce60-11e2-bf5f-001d092acafe
                Event Xml:
                <System>
                <Level>2</Level>
                <Task>100</Task>
                <TimeCreated SystemTime="2013-06-06T04:23:54.000000000Z" />
                <EventRecordID>41128</EventRecordID>
                <Security />
                </System>
                <EventData>
                <Data>179cc</Data>
                <Data>01ce626d9be3948b</Data>
                <Data>e5a81069-ce60-11e2-bf5f-001d092acafe</Data>
                </EventData>
                </Event>
                If you'd like to send me some debugging symbols, I'll see if I can get more details for you.
                  I recommend un-installing the DC8.15 program and then re-installing it. Something must be corrupted in the install. Your serial number, user name and registration code should persist, so you will not need to re-register it.
                    The uninstall and reinstall worked without incident. But, I'm still getting the same exception when I try to open the DC Tunes Library. This time I did not change the DC Tune Library directory and kept the default.
                      Hi Carl,
                      I do not know; I have asked Rick if he has any ideas about it. I have sent him the link to this thread.
                        Carl
                        Hmm, this is strange. There were no changes to the DCTunes library files for this update.
                        Here is another thing to try
                        1. Start DC8 and figure out where the DCtunes library path is setup to point to.
                        2. Go to that directory and remove (or rename) DCTuneDB.xml and DCTuneDB.Bak.xml
                        3. Now try starting DC8->DCtunes again and let it rebuild the library.
                        Rick
                          Rick and Craig,
                          I restarted my system and all is well. DC8.15 is able to open my DC8.13 Tunes Library and playlists.
                          Sorry for causing you concern. Thank you for your support AND a GREAT PRODUCT!
                            Hi Carl,
                            Good news to hear, indeed!
                              Craig: Since I installed DC8.15 I can only see .WAV files in the directory. Why can't I see the other files, e.g. mp3 or pkf or ses?? I can see them in Windows File manager but not when I go to access the files in the directory when editing in DC8.15. Is there some control that is turned off (or on) that I need to undo. If so, I can't find it. Otherwise all is well. best, Eric
