The question arose recently, and I paraphrase: "What is the easiest way to reverse to flat my phono preamps RIAA curve using Diamond Cut?"
The easiest way is as follows:
1. Launch the Virtual Phono Preamplifier
2. Under "Preamp Hardware", check the Standard RIAA Curve checkbox.
3. Under "Record Type", check the "Acoustical" checkbox.
That will convert an RIAA preamp curve into a flat curve (assuming that an RIAA Preamp is used in the signal transfer chain).
