I have some LPs which I am attempting to clean up, and they contain noises which are somewhere between a click and a small thump. The impulse filter doesn't touch them, and when I isolate them there is nothing visible in the wave file to indicate the cause. I have managed to pin down the locations of some, using repeated "Play from here" trials, and finding where the noise is heard and where it isn't, but there is still nothing to see.
At least some of the cases seem to occur at points where the music changes pitch, for what that is worth (if anything).
In some cases I have managed to eliminate the noise by judicious cut-and-pasteover, but in some even this fails. I can totally replace the suspect area and still have the noise!
Has anyone ANY suggestion for dealing with such cases? Would anyone be willing to look at a couple, if I were to post small sections of wave files on alt.binaries.test (or the location of your choice. I have a small ISP provided area where I can put HTML and such like, but they don't allow wave files or mp3s. Maybe zip files would work, I haven't tried them. Or I could rename the files as jpg files.
Anyway, any help would be welcome.
