Applause
  • Applause
    Hello,
    I am new here and I would like to say Hi.
    I recently purchased Millennium and I have a question.
    I have many live LP?s that contain applause. Can anyone recommend a method of removing this unwanted applause?
    Thank for your help.
    Rick Barber
    Re: Applause
    Thank you for the quick reply. I will give the impulse filter a try.
      Re: Applause
      Hi Rick -
      If these are commercial releases, they usually have applause after the song is complete or at specific points (such as solos, etc.) If there is nothing else important going on, you can simply fade out the applause quickly (under the edit button).
      If the applause is near the microphone, such as in some noncommercial recordings, I've had good luck making it less intrusive by lightly "de-clicking" using the impulse filter. You have to experiment with it a bit, but sometimes you can make it so that the applause sounds more natural if you de-click that portion of the file.
