Question
  • Question
    Hello,
    Sorry to bother you guys again but I have one last question. I used the virtual valve adapter with the high end audio preamplifier with triode (12AX7) setting. Or should I have used another setting in virtual valve adapter? I used it on Aerosmith - Toys In The Attic (1973) (old memories). It worked very well but I think that tyler's voice comes out a little to strong. Is there any way to fix that or bring it in closer to the music? Any help would be appreciated.
    Thank you,
    Peter
    You can re-balance the various aspects of the sound by applying one the the graphic equalizers. Perhaps you need to reduce the level of the signal around 1000 Hz to achive the results that you desire. To do that, bring up the graphic EQ and, while previewing it, adjust it (500 Hz, 1,000 Hz, and 2,000 Hz bands) until Tyler's voice is in the proper balance with respect to the rest of the music.
