i would like to be able to listen to a radio broadcast with a sports event but it is not in sync. i want to be able to do this in real time. i know of a gadget for $150 that will do it. anyone know a way to do this with my computer? i have a win tv usb unit with an fm reciever on it attatched to an external antenna.
radio audio ahead of video on t.v.
Creating Real Time Delay with Diamond Cut
If you need to create a time delay in real time, it can be done with Diamond Cut DC6 software. Here is how to do it:
1. Bring up the Multifilter
2. Remove all filters and/or effects from the Multifilter
3. Drag the Echo Effect into the Multifilter display
4. Click on it and set it up as follows:
*Delay 1: 0 to 5 Seconds
*Level 1: 1.00
*Delay 2: 0 to 5 Seconds
*Level 2: 1.00
*Feedback: 0.00
*Output Mix: Wet (slider control all the way up)
*Uncheck the following checkboxes on the Echo Effect: Low Pass Echo, High Pass Echo, Invert Echo
5. Now, just "Live Preview" the Multifilter and adjust the delay controls until you achieve sync.
keywords: Delay Time CompensationLast edited by Craig Maier; 01-15-2007, 03:39 PM."Who put orange juice in my orange juice?" - - - William Claude Dukenfield
