Hello:
I wanted to post this message to see if any of you have come across the following scenario:
As previously posted, I have been unable to successfully process/edit a wav-file in a Multi-Filter format, using, in this order, the CNF with an 8,192 FFT, Dynamic Noise Filter, VVA, Reverb, and EQ--all without getting the previously posted error message. Since then, I've separately run the CNF, and then run the successive Multi-Filter with the above-stated filters. That seemed to work well, that is, until today.
Now, however, I'm getting the following error message: "DCART32 caused an invalid page fault in module USER.EXE @0003.0000a5d4." Further error messages report the system running dangerously low in resources, as well as a fatal exception OE occuring at 017E.BFF9DFFF. Help!
My Diamond Cut/Millennium (version 4.18)is the only program running while recording and/or performing edits (the screen saver and virus scan have been disabled).
Is there anyone else who has experienced this problem? Or is this a unique occurance associated with version 4.18, which, as I've previously read, not too many people seem to have (as to why I have it, I cannot say--it was the CD-ROM version that was sent to me when I ordered it from Tracer Technology in March of this year).
Thanks, in advance, for your help.
Regards,
David
Regards,
David
