Just a question -
After creating a wav file from an acoustic recording, should I apply "reverse RIAA phono) equalization settings before using the impulse filter? That doesn't make any logical sense to me, but it seems to result in a better overall sound.
Similarly, my turntable doesn't have a 78 speed. I've recorded 78s at 45 and then used the speed change to make it play at the correct speed. I get the best results running the "reverse RIAA Phono," then the impulse filter, then fixing the speed. It's just a little hard to adjust the impulse filter because the sound is so slow.
Anyway, do these sound like reasonable things to do with these media?
And one more thing I've found... I get a stereo signal from these early 78s and then subtract l-r, which gives almost complete noise (almost no real signal). Then I subtract that noise from the "true" signal. I've experimented with subtracting from the left, the right, and from the l+r combined. My sense is that it should be from l+r combined, but I don't know if that's technically what I should do or not. Any ideas? It seems to be a nice alternative to the continuous noise filter that pulls out a lot of scrapes, scratches, pops and high ends without hurting the signal.
