The DCart10 Overtone Synthesizer can now be made to produce sharp or flat overtones (just like the sub-harmonic synthesizer). It's range runs from 0 (perfect) to +200 cents on the sharp side of things. On the flat side of things, it can be operated from 0 (perfect) to -200 cents. Looked at in a different way, this gives you a range of +/- 2 semitones (each side of perfect). The advantage of this function is that often music sounds better when the harmonics produced are not perfect multiples of the source signal. To gain even more flexibility with this new feature, you can place multiple overtone synthesizers in the multi-filter to create more interesting top-end effects/simulations.
