Combining files
  • Combining files
    I'm a newby with this version and just tried to combine two 24/96k mono files (left and right channels) into a stereo file. Dcart says they're mono but when I clicked Combine it says whatever file on the top tab is not mono. I did a Mono to Mono file conversion on both of them but that didn't solve the problem.
    Thanks for the forum's help.
    John
    Does it work if you first convert the files to 16 bits/44.1 kHz?
      Hi Craig,
      Just converted these files to 16/44.1k and got the same message. Thanks for your help.
        Apologies Craig. This was a bit of operator error on my part. Files combined fine at full res.
        Thanks.
        John
          Ok - glad that it worked out ok.
