A while back I had to move all folders for wavs I created with Diamond Cut 8 on a different computer to a new
computer. Some of the wavs contained session files. Opening them up with DC10 would pop up a warning message
indicating it was unable to load all presets or something to that effect. It was a yes or no response. No matter which
one I selected the result was the same. The wav file was deleted.
I went in to each folder where my wav files were and deleted the session files. Then the wavs loaded. Nothing deleted.
It seems like the program should never delete a wave file but just ignore or delete the session file if it is unable to load the
session. I was using DC8 on the new computer before upgrading with the same problem I believe.
