DirectSound Error: Unknown Error Number
  • #16
    In post 14 I mentioned using the "control panel" to select the sound devices, then the recording, then the advance tab. Under the advance section you can change the sample rate. Using the help window in windows 10 you can find the path to the sound card in your system.
    Are you using an external sound converter?
    • #17
      These are found at the Diamond Cut Productions edit / preferences / soundcard tab.
      • #18
        If you are still having difficulties with this, please call our support line at 973-316-9111.
        • #19
          Not using an external sound card.
          Using Prodigy XFi-nrg. Will probably give you a call at some point.
          • #20
            If you set your edit/preferences/soundcard to the computers's on board sound system do you still get that error?
