Random Noise by Color (chart) and signal production
  • Random Noise by Color (chart) and signal production
    Random Noise by Color (Various Noise Distributions)
    Sometimes it is desirable to mask background audio using random noise. Your Diamond Cut Make Waves Generator (found under the Edit menu/Make Waves) provides you with various distributions of noise that you can produce. Random noise can be used to mask conversations or to simply create a background environment more conducive to sleep or relaxation. Check them out and hear what they sound like.
    Color
    (or type)
    Characteristics Slope Density
    White Equal Energy per unit Hertz Flat Uniform
    Pink Equal Energy per unit Octave -3 dB/Octave 1/F
    Brown Analogous to Brownian Motion -6 dB/Octave 1/F^2
    Red Another name for Brown Noise -6 dB/Octave 1/F^2
    Blue Azure Noise (proportional to F) +3 dB/Octave F
    Green Pink Noise with Emphasis at 500 Hz Non-Linear Somewhat Subjective
    Violet Differentiated White Noise +6 dB/Octave F^2
    Grey Psychoacoustic equal loudness Curves Proportional to SPL Varies with loudness
    Seismic Random Noise below 20 Hz -3 dB/Octave In-audible
    Black Analogous to black body radiation Silence Edit/Mute
    These various Random Noise distributions (by color or mathematical distribution) can be created directly via the Make Waves Generator. They can also be found as a series of White to X Color Multifilter Presets portion of the software program.
    Copyright (c) 1996-2023 Diamond Cut Productions, Inc.
    I guess that this new set of features could be called either Hi-Fi to Dine By or The Relaxer". It could also be called "The Sound Masker".
