I am trying to restore Chad & Jeremy Zanzibar Sunset, and at two points in the song there is a very loud cascade of chimes. Unfortunately, on my copy of the vinyl, these passages are extremely distorted. I have used the Continuous Noise Flat Line filter with some moderate success - applying the filter only to the section with the chimes. In the resulting file, there is a bit of a transition as the filter kicks in, but it is not too obvious. Most people won't here it, although it annoys me.
I have tried pretty well every other filter with no joy.
Anyone else encountered this type of problem? Any suggestions?
Update: After reading some other posts, I decided to look at the spectrum more closely. The unfiltered recording had a slight but noticable 60 Hz hum which the harmonic filter took out. But there were a couple of spikes, one at aprox 6500 Hz, one at aprox 6000 Hz and a third at 540 Hz. I have no idea where they came from, could be the turntable, or the sound card or they might be on the vinyl recording. But notch filters took them out quite nicely, and after that the cleanup process went much smoother. I did not need to do anything special with the chimes, just the regular impulse and continuous noise filters.
I have not noticed this problem on other recordings, but I am going to go back and look at some of them just to be sure.
