Group,
The subject of "what stylus to use" to play back the Edison Diamond Disc's has been brought up before. I have, though, I slightly different question.
In the Diamond Cut User's guide (Nicely written, I might add), the stylus called out for the Diamond Disc's is 3.7 mil spherical or non-truncated conical stylus. This size of stylus is very close to the actual size used by Edison. From a drawing I found (Sketch dated June 28,1917 from Edison Laboratory), the diamond stylus has a 0.00375 to 0.0035 inch radius which then went at a 60 degree angle up. It appears that the Diamond Cut value is very close to that actually used.
Question then, I have a Stanton 500.V3 that I want to use for Diamond Disc records...can I just order a Stylus that is the same as the actual Diamond Disc stylus used ? Is 3.7 mil a standard size ?
Also, the Edison reproducer had the stylus vertical to the record surface. Does the slight angle with the Stanton Stylus cause a problem ?
Regards,
Regards,
