Greetings;
I wanted to ask the collective minds about a strange phenomenon I've discovered when I transfer records to see if anyone has experienced this or may know where to point me in troubleshooting this. After I transfer a record, when listening back to the file, sometime around the second 1/2 of a record side, I hear a soft knocking sound during the softest parts of the record (mostly in between songs) and cannot understand what is causing this. The cadence appears to be timed with the rotation of the platter. This does not show up at the start of the record though
This happens with most any record I play and is very intermittent in nature; sometimes I hear it only once, other times I hear it multiple times (even replaying the same record side). I'm very pleased with this TT overall but this knocking drives me nuts and it creates more work for me in the process. I have also experienced this on one pass and then it disappears on the next pass (same spot on the record).
As I bought this turntable used a few years ago, I noticed the sub platter did have a chunk missing from it but am not sure if this would cause the knocking I hear.
As stated, this is an MMF 5.1 fitted with an Ortofon 2M Blue cartridge, acrylic platter and a cork mat (both Music Hall). At first, I noticed the issue with just the acrylic platter installed but now hear it with the original metal platter also.
I can provide a short clip if that would help.
Thanks for the help...
