Installing the software on a non-internet computer
Installation on ‘”internet-isolated” computer (DAWs), often found in Forensics laboratories involves a different procedure to maintain security. It involves the use of a proxy computer. Since your license permits two computers for one user, here is how to install the software on a computer that does not touch the internet. Install the software and register it on a non-lab computer (your administrative computer for example). This is your proxy computer. Test the software and make sure it is registered as indicated under the “Help About Diamond Cut Restoration Tools”. Copy and Paste the Serial Number and Registration Codes into your Word Processor. Place that document containing those two numbers onto a USB Memory stick. Then, make a copy of the .msi installer onto a USB memory stick (thumb drive). Bring the USB memory stick and move the .msi installer into a directory under the lab computer’s C drive. Install the program. Next, bring up the serial number and registration code on the lab computers word processor. Copy the Serial Number and paste it into the Serial Number field of the software. Next, copy the Registration Code and paste it into the registration field of the software. We recommend that after the process has been completed that you delete the Forensics software from the proxy computer.
(Lab Computer Installation)
