Tip of the Day
  • Tip of the Day
    - Tip of the Day
    This feature is normally displayed on the splash screen after you launch the software. It can also be invoked under the help menu item. It provides useful hints on the operation of the software contained within roughly 330 total tips. It advances through the list one item at a time each time the software is opened. When it gets to the last tip, it returns to the first item in the listing and starts the sequence over again. The tip file is common to two Diamond Cut Software programs, so some tips may not be relevant to your application(s). If you are not interested in using the tip of the day feature, un-check the box that indicates "Show Tips on Start-Up" found in it’s dialog box.
