Measurements Tool Finder (table)
  • Measurements Tool Finder (table)
    - Measurement Tools Table
    Measurement Stimulus System Response System
    Acoustical Signature Calibrated microphone driving sound card input Spectrogram
    Aliasing Products Swept Sine Wave (Make Waves Generator) Spectrum Analyzer
    Amplifier Linearity Triangle Wave Generator (Make Waves) Waveform Display Window
    Amplitude Measurements Time Domain Signal (highlighted by user) Waveform Statistics in Forensics Menu
    Amplitude vs. Frequency Any signal requiring analysis Spectrum Analyzer
    Amplitude vs. Time Any signal requiring analysis Waveform Display Window
    Analog Tape Authentication Look for line frequency or multiple line frequency spectral spikes or look for a higher order noise roll-off rate Spectrum Analyzer operating in high resolution mode
    Analog Tape Recorder Tape Head Azimuth Alignment Azimuth Reference Tape XY Display / Vector-scope
    Ballistics Fingerprint Audio Recording of ballistics events to be compared Spectrogram
    Average Phase Angle Any Binaural Signal Averaging Selection Box in the XY Display
    Cross-talk Sine Wave into One Channel from the Make Waves Generator; Terminate the opposite channels input with the proper impedance Spectrum Analyzer or VU Meters
    DC Offset Terminate input with proper input impedance Waveform Display Window
    Dynamic Range Any combination of signals requiring analysis VU Meters with Peak Hold
    Fall Time Any signal requiring analysis Waveform Display Window and Time Display with Markers
    Frequency & Amplitude vs. Time Any signal requiring analysis Spectrogram
    Frequency Distribution Any signal requiring analysis Spectrum Analyzer
    Frequency Ratio Any signal requiring analysis XY Display / Vector-scope
    Frequency Response Swept Sine Wave or Random Noise made by the Make Waves Generator VU Meter (when using the Swept Sine Wave) or the Spectrum Analyzer (when using the Random Noise Generator)
    Hard Disc Recording Time Available Any signal being recorded Recording Function
    Instantaneous Frequency Any signal requiring analysis Waveform Display Window and Time Display with Markers. Calculate: F= 1/t
    Inter-modulation Distortion Dual Sine Wave Tones made with the Make Waves Generator and summed together with “Paste Mix” Spectrum Analyzer
    Left Channel vs. Right Channel Any signal(s) requiring analysis XY Display / Vector scope
    Linearity Triangle Wave created using the Make Waves Generator Waveform Display Window
    Noise Floor Properly Terminated Input Spectrum Analyzer
    Peak Amplitude Any signal requiring analysis VU Meter using the Peak Hold feature
    Phase Angle Any pair of signals having coherence XY Display / Vector-scope
    Phase Margin of equipment having a control loop system (1st& 2nd order) Stereo Square Wave Generator (Make Waves) Time display window (dampening factor of ‘ring-out’)
    Phase vs Time Two Channels with respect to one another Forensics Menu – View Phase vs Time
    Power Amplifier Frequency Response vs. Output Swept Sine Wave (Make Waves) Proper Loading resistor and True RMS reading Voltmeter
    Real Time of an Event Any signal requiring analysis Timer Recording with Time and Date Stamping
    Recording Position Any signal being recorded Recording Function
    Relative Amplitude (Scalar) Any combination of signals requiring analysis VU Meter
    Relative Loudness Any combination of signals requiring analysis VU Meter
    Rise Time Any signal requiring analysis Waveform Display Window and Time Display with Markers
    Room Acoustical Balance Random Noise Generator (Make Waves) Spectrum Analyzer
    Room Acoustical Propagation Delay & Reflection Calibrated microphone driving a sound card input & an Impulse source like a handclap or an impulse created with the “Pencil” feature Waveform Display Window, Markers and Time Display Feature
    Signal to Noise Ratio Sine Wave @ 0 dB vs. Noise Floor Spectrum Analyzer
    Slew Rate Square Wave Generator (Make Waves) Waveform Display Window and Time Display with Markers
    Sound Card Performance Please Refer to Application Note 2 (AN-2) Please Refer to Application Note 2 (AN-2)
    Sound Card Recording Level / Clipping Audio signal applied to sound Card Recording Function with recording VU meter and peak indicator
    Stereo Separation Sine Wave into One Channel from the Make Waves Generator; Terminate the opposite channels input with the proper impedance Spectrum Analyzer, VU Meters or X-Y Display
    Tape Recording Speed Any analog tape recorded signal Spectrum Analyzer
    Time Derivative (dV / dt) Any signal requiring analysis Waveform Display Window and Time Display with Markers
    Time Interval between Events Markers Time Display Feature
    Total Harmonic Distortion (% THD) Any Audio Device requiring performance testing using a Sine Wave stimulus (Make Waves) Spectrum Analyzer with “Show THD” function and “Show Peak” enabled
    Transient Response Any Active Audio Device with a control loop with a Square Wave applied (Make Waves Generator) Waveform Display Window
    Turntable RPM Neon or Fluorescent Lamp connected to a known Frequency Source Printable Strobe discs found in the your software.
    Voice Print comparison Audio Signal of Voice(s) to be compared Spectrogram
    Waveform Statistics Forensics Recordings Histogram or Histogram vs Time
    Whisper Amplifier/Enhancer Forensics Audio Recordings with very Weak “far” parties Whisper Enhancer (Forensics Version Only)
    Wow and Flutter Sine Wave (Make Waves) Spectrum Analyzer
