Hard Disc Drive Recording Space Requirements
  • Hard Disc Drive Recording Space Requirements
    Hard Drive Recording Space Consumption
    How much hard drive space will you need for your next recording? This handy chart should get you in the ballpark.
    Digitization Disc Space Consumption as a function of Recording Mode and Sample Rate @ 16 bit resolution
    Sample Rate & Recording Mode Mbytes per Minute
    192 kHz Monophonic 22.500
    192 kHz Stereophonic 45.000
    96 kHz Monophonic 11.250
    96 kHz Stereophonic 22.500
    48 kHz Monophonic
    (Pro-Audio)
    5.760
    48 kHz Stereophonic
    (Pro-Audio)
    11.520
    44.1 kHz Monophonic 5.292
    44.1 kHz Stereophonic
    (Compact Disc)
    10.584
    22.05 kHz Monophonic 2.646
    22.05 kHz Stereophonic 5.292
    16.000 kHz Monophonic
    (Forensics)
    1.920
    16.000 kHz Stereophonic
    (Forensics)
    3.840
    11.025 kHz Monophonic 1.323
    11.025 kHz Stereophonic 2.646
    Note 1 - Values are given for one process only (such as recording).
    Note 2 - Values are given for 16-bit resolution only.
    Note 3 - Multiply the above storage rates X 1.5 for 24-bit recording.
    Note 4 - Windows currently operates with a 2 Gigabyte limit on .wav file
    size.
