The attached set of 5 presets will allow you to generate Random Impulses using the DC Live Forensics version of the software. You will need to start with a "makes waves" file consisting of Monophonic, 44.1 KHz, 16 bit random noise at the -10 dB level. Then, apply that signal to any of these presets in your multifilter and the result will be randomized impulses. This can be used to characterize room acoustics or to simply simulate the old retro sound of a mechanical record by Paste Adding it to a modern recording. If you do not have Live / Forensics, download the Live / Forensics demo from our website located at www.diamondcut.com and use it to create the file that you desire. If you need more than 1 minute worth of random impulses, use the cancatanate function in your DC5 software to elongate it.
Random Impulse Generator Presets
Last edited by Craig Maier; 07-28-2019, 09:16 PM."Who put orange juice in my orange juice?" - - - William Claude Dukenfield
