HI!
I may have a somewhat strange question here; hope I made myself clear:
Since there is about 10 meters from my turnable and flat pre-amp set-up to my PC, I sometimes use a stationary Philips CD-recorder (a CD player with recording facilities) that is connected directly to the line-out from the flat phono-pre-amp. I then transfer the 78's directly to CD through my flat phono pre-amp. Thereafter I take the CD to the PC and rip it into the DC7 using the rip function on the program. From there I start to do the normal restoration process.
QUESTION; does this seem to be a good way to do this, or is there some obvious possibilities for quality loss? Should I rather use a long audio wire from the out put on the flat phono pre-amp and to the input on the hard disc on the PC??
Comments, please..
Best regards
jan
Comments, please..
Best regards
jan
