Remove DC files
  • Remove DC files
    Just upgraded to DC*.13
    Search of all disks shows 169 files starting with DC
    How do I remove ALL UN NEEDED files and previous versions DC7,DC8 ?
    Hi Walter,
    You can use the "Add or Remove" feature found under the Windows "Control Panel" to remove earlier versions of the software.
      I understand how to remove files. My question is which files other than programs can I safley remove from the 169 found in search?
        I can not list each and every file that is used by the program. It needs all of them except for the ones that are removable by the Add or Remove feature. That is the only way that I can describe what is needed and what is not needed. Some files must remain in the registry to prevent software hacking.
          Thanks for reply.ill start there.
            It's always best to let the computer do the work.
              nice post------------
              We offer self paced microsoft braindump web designing training for you! We have 650-251 tutorial and 642-566 guide covering Photoshop and other design applications so you will become expert.main site braindumps For more details about this product visit PMI and also see on The Johns Hopkins University ,best wishes.
