Dan,
The concept of "ENOB" revolves around the idea that an "analog" voltage is converted to a "perfect" digital result. Thus, the noise present will degrade the conversion to digital but once in the digital world, the signal isn't changed by most noise present. Each time that you move through the conversion, though, the effective number of bits can be impacted.
There are noise reduction methods that can help greatly with signal recovery in noise environment cases, but for audio and 16 bits, the actual number is much less than 16.
By the way, the D to A process uses precision resistors that convert the digital levels to analog levels. If you calculate the temperature change to these resistors value verses a couple of degrees, you will quickly find that your 24 bits isn't even 16 bits with normal temperature variation in a room.
In the past, I worked with precision resistors that were placed in a temperature controlled oil bath for accurate measurements. The resistors were made by Julie Research in New York City. The owner, Julie ???? , invented the original Operational Amplifier (OP).
