I've encountered a minor problem burning single channel files on my new puter. It's an HP running WinXP with an internal burner and I'm using the burning apps that came with the machine...HP's Record Now and MusicMatch. Both apps refuse to accept single channel files...the MusicMatch error message says that it can only accept 16 bit files, which all mine are. The workaround is to split the single channel file back to 2-channel mono as the raw file is...both apps then accept the file. Has anyone else encountered this problem? Thanks!
-Danny Gilbert
-Danny Gilbert
