New Flat Phono Preamp
This is a sticky topic.
  • New Flat Phono Preamp
    We are proud to introduce a new Flat Phono Preamp which is designed to work in conjunction with the DCArt10.5 Software Virtual Phono Preamp:
    .https://www.diamondcut.com/st3/produ...gory/hardware/
    Here is a direct link to the .pdf of the DCP-47K-F Preamplifier Data Sheet:
    http://www.diamondcut.com/Downloads/...ifications.pdf
    Question Craig,
    Will this preamp be available as a "B" model? I am slowly upgrading to a balanced system for my restorations and was wondering if a model would be available for our needs?
      Does a "B" model mean that it would have balanced outputs (or something else)?
        Yup, I'm looking for a balanced outputs to use with my ESI Julia card.
          Ok - the outputs of the DCP-47K-F are single-ended. There are no plans to create a balanced output version of this product.
            Hi DJ -
            I do recall that we used to have a balanced output phono preamp block (I was the guy who designed it - but it was a long time ago). I believe it was called the CTP-2000. You needed two units, one for each channel - - - they were mono-block flat preamps. Perhaps you can find a pair of them on ebay or maybe put out the call for one on the classified section of this forum. Somebody probably has some of these out there.
            keywords: CTP-2000 Balanced Output Flat phono preamp differential output flat preamplifier
              Hi again, DJ,
              Here is another lead which may yield a set of the CTP-2000 balanced output preamps. Contact Tracer and ask if they have any new old stock on them. Write an email to Jeff and ask about it. His email is jeffk@tacertek.com
                Hi again, one more time, DJ
                I was in error when I called out the DCP-2000 to have balanced outputs. That is not the correct model. The mono-block flat preamp with balanced outputs was the CTP-1000B. Two are required for stereo transfers. Sorry about that.
                keywords: ctp-1000B, balanced output preamp
                differential output preamp
                  DCP-47K-F Specification Qualifications:
                  1. The published specifications for the DCP-47K-F flat phono preamplifier are 'typical' values
                  2. The published specifications for the DCP-47K-F flat phono preamplifier are 'Subject to Change without Notice'.
                  3. The 47 kOhm input termination resistance is a resistance value, not a complex impedance value.
