In DC5.03 when I try to copy a section of a wave I got the message:
You are attempting to perform selective filtering with a destination file that is not long enough. You must either create a destination file of sufficient length of turn off sync mode.
I go under Edit/Preferences/Display and remove the check under Sync Mode Scroll Tracking. Do APPLY and start again. The same message.
I quit DC5 and rerun it. No more success.
1) In DCART32 the selection was append to an empty file in this situation. Is-it possible to configure DC503 to do the samething.
2) How do I create a destination file of sufficient length.
Thanks
Gilles Desautels
Thanks
Gilles Desautels
